1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkBlueObeliskData.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkBlueObeliskDataParser.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkMoleculeMapper.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkMoleculeToAtomBallFilter.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkMoleculeToBondStickFilter.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkMoleculeToLinesFilter.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkMoleculeToPolyDataFilter.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkPeriodicTable.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkPointSetToMoleculeFilter.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkProgrammableElectronicData.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkProteinRibbonFilter.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/Domains/Chemistry/vtkSimpleBondPerceiver.h"
59  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Domains/Chemistry/vtkDomainsChemistryModule.h"
60  )
61 endif()
62
63 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
64  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkDomainsChemistry-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkDomainsChemistry-hierarchy.txt")
65 endif()
66
67 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
68  foreach(file
69  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so.5.13"
70  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so.1"
71  )
72  if(EXISTS "${file}" AND
73  NOT IS_SYMLINK "${file}")
74  file(RPATH_CHECK
75  FILE "${file}"
76  RPATH "\$ORIGIN")
77  endif()
78  endforeach()
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
80  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDomainsChemistry-pv5.13.so.5.13"
81  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDomainsChemistry-pv5.13.so.1"
82  )
83  foreach(file
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so.5.13"
85  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so.1"
86  )
87  if(EXISTS "${file}" AND
88  NOT IS_SYMLINK "${file}")
89  file(RPATH_CHANGE
90  FILE "${file}"
91  OLD_RPATH "\$ORIGIN:"
92  NEW_RPATH "\$ORIGIN")
93  if(CMAKE_INSTALL_DO_STRIP)
94  execute_process(COMMAND "/usr/bin/strip" "${file}")
95  endif()
96  endif()
97  endforeach()
98 endif()
99
100 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
101  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so" AND
102  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so")
103  file(RPATH_CHECK
104  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so"
105  RPATH "\$ORIGIN")
106  endif()
107  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDomainsChemistry-pv5.13.so")
108  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so" AND
109  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so")
110  file(RPATH_CHANGE
111  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so"
112  OLD_RPATH "\$ORIGIN:"
113  NEW_RPATH "\$ORIGIN")
114  if(CMAKE_INSTALL_DO_STRIP)
115  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.13.so")
116  endif()
117  endif()
118 endif()
119
