1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKRenderWidget.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKWin32Header.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QFilterTreeProxyModel.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKApplication.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKInteractor.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKInteractorAdapter.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKOpenGLNativeWidget.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKOpenGLStereoWidget.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKOpenGLWindow.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKRenderWindowAdapter.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/QVTKTableModelAdapter.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkEventQtSlotConnect.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQWidgetRepresentation.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQWidgetTexture.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQWidgetWidget.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtAbstractModelAdapter.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtAnnotationLayersModelAdapter.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtConnection.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtDebugLeaksModel.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtDebugLeaksView.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtTableModelAdapter.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/vtkQtTreeModelAdapter.h" 69 "/builds/gitlab-kitware-sciviz-ci/build/VTK/GUISupport/Qt/vtkGUISupportQtModule.h" 73 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so.5.13
" 76 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so.1
" 78 if(EXISTS "${file}
" AND 79 NOT IS_SYMLINK "${file}
") 82 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 85 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 86 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkGUISupportQt-pv5.13.so.5.13
" 87 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkGUISupportQt-pv5.13.so.1
" 90 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so.5.13
" 91 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so.1
" 93 if(EXISTS "${file}
" AND 94 NOT IS_SYMLINK "${file}
") 97 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 98 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 99 if(CMAKE_INSTALL_DO_STRIP) 100 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 106 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 107 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
" AND 108 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
") 110 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
" 111 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 113 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkGUISupportQt-pv5.13.so
") 114 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
" AND 115 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
") 117 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
" 118 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 119 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 120 if(CMAKE_INSTALL_DO_STRIP) 121 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkGUISupportQt-pv5.13.so
") 126 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 127 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkGUISupportQt
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/GUISupport/Qt/LICENSE
