1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus
47  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkCPExodusIIElementBlock.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkCPExodusIIInSituReader.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkExodusIICache.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkExodusIIReader.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkExodusIIReaderParser.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkExodusIIWriter.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkModelMetadata.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkCPExodusIINodalCoordinatesTemplate.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkCPExodusIIResultsArrayTemplate.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkExodusIIReaderPrivate.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkExodusIIReaderVariableCheck.h"
58  "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Exodus/vtkIOExodusModule.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkCPExodusIINodalCoordinatesTemplate.txx"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Exodus/vtkCPExodusIIResultsArrayTemplate.txx"
61  )
62 endif()
63
64 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
65  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOExodus-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOExodus-hierarchy.txt")
66 endif()
67
68 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
69  foreach(file
70  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so.5.13"
71  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so.1"
72  )
73  if(EXISTS "${file}" AND
74  NOT IS_SYMLINK "${file}")
75  file(RPATH_CHECK
76  FILE "${file}"
77  RPATH "\$ORIGIN")
78  endif()
79  endforeach()
80  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
81  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExodus-pv5.13.so.5.13"
82  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExodus-pv5.13.so.1"
83  )
84  foreach(file
85  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so.5.13"
86  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so.1"
87  )
88  if(EXISTS "${file}" AND
89  NOT IS_SYMLINK "${file}")
90  file(RPATH_CHANGE
91  FILE "${file}"
92  OLD_RPATH "\$ORIGIN:"
93  NEW_RPATH "\$ORIGIN")
94  if(CMAKE_INSTALL_DO_STRIP)
95  execute_process(COMMAND "/usr/bin/strip" "${file}")
96  endif()
97  endif()
98  endforeach()
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
102  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so" AND
103  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so")
104  file(RPATH_CHECK
105  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so"
106  RPATH "\$ORIGIN")
107  endif()
108  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExodus-pv5.13.so")
109  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so" AND
110  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so")
111  file(RPATH_CHANGE
112  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so"
113  OLD_RPATH "\$ORIGIN:"
114  NEW_RPATH "\$ORIGIN")
115  if(CMAKE_INSTALL_DO_STRIP)
116  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExodus-pv5.13.so")
117  endif()
118  endif()
119 endif()
120
