1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Export 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkExporter.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkGLTFExporter.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkIVExporter.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkJSONDataSetWriter.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkJSONRenderWindowExporter.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkJSONSceneExporter.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkOBJExporter.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkOOGLExporter.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkPOVExporter.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkRIBExporter.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkRIBLight.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkRIBProperty.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkSVGContextDevice2D.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkSVGExporter.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkSingleVTPExporter.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkVRMLExporter.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkX3D.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkX3DExporter.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkX3DExporterFIWriter.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkX3DExporterWriter.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkX3DExporterXMLWriter.h" 68 "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Export/vtkIOExportModule.h" 72 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 73 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkIOExport-hierarchy.txt
vtk/hierarchy/ParaView/vtkIOExport-hierarchy.txt
") 76 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 78 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so.5.13
" 79 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so.1
" 81 if(EXISTS "${file}
" AND 82 NOT IS_SYMLINK "${file}
") 88 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 89 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExport-pv5.13.so.5.13
" 90 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExport-pv5.13.so.1
" 93 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so.5.13
" 94 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so.1
" 96 if(EXISTS "${file}
" AND 97 NOT IS_SYMLINK "${file}
") 100 OLD_RPATH "\$ORIGIN:
" 101 NEW_RPATH "\$ORIGIN
") 102 if(CMAKE_INSTALL_DO_STRIP) 103 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 109 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 110 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
" AND 111 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
") 113 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
" 116 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExport-pv5.13.so
") 117 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
" AND 118 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
") 120 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
" 121 OLD_RPATH "\$ORIGIN:
" 122 NEW_RPATH "\$ORIGIN
") 123 if(CMAKE_INSTALL_DO_STRIP) 124 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv5.13.so
") 129 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 130 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkIOExport
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/LICENSE
