1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/GLTFSampler.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkAVSucdReader.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkBYUReader.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkBYUWriter.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkChacoReader.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkFacetWriter.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkFLUENTReader.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGAMBITReader.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFDocumentLoader.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFReader.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFTexture.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFWriter.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkHoudiniPolyDataWriter.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkIVWriter.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkMCubesReader.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkMCubesWriter.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkMFIXReader.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkOBJReader.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkOBJWriter.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkOFFReader.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkOpenFOAMReader.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkParticleReader.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkProStarReader.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkPTSReader.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkSTLReader.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkSTLWriter.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkTecplotReader.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkWindBladeReader.h" 75 "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Geometry/vtkIOGeometryModule.h" 79 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkIOGeometry-hierarchy.txt
vtk/hierarchy/ParaView/vtkIOGeometry-hierarchy.txt
") 83 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 85 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so.5.13
" 86 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so.1
" 88 if(EXISTS "${file}
" AND 89 NOT IS_SYMLINK "${file}
") 95 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 96 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOGeometry-pv5.13.so.5.13
" 97 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOGeometry-pv5.13.so.1
" 100 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so.5.13
" 101 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so.1
" 103 if(EXISTS "${file}
" AND 104 NOT IS_SYMLINK "${file}
") 107 OLD_RPATH "\$ORIGIN:
" 108 NEW_RPATH "\$ORIGIN
") 109 if(CMAKE_INSTALL_DO_STRIP) 110 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 116 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 117 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
" AND 118 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
") 120 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
" 123 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOGeometry-pv5.13.so
") 124 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
" AND 125 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
") 127 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
" 128 OLD_RPATH "\$ORIGIN:
" 129 NEW_RPATH "\$ORIGIN
") 130 if(CMAKE_INSTALL_DO_STRIP) 131 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.13.so
