1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/H5Rage 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/H5Rage/H5RageAdaptor.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/H5Rage/vtkH5RageReader.h" 49 "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/H5Rage/vtkIOH5RageModule.h" 53 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkIOH5Rage-hierarchy.txt
vtk/hierarchy/ParaView/vtkIOH5Rage-hierarchy.txt
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 59 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so.5.13
" 60 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so.1
" 62 if(EXISTS "${file}
" AND 63 NOT IS_SYMLINK "${file}
") 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 70 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOH5Rage-pv5.13.so.5.13
" 71 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOH5Rage-pv5.13.so.1
" 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so.5.13
" 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so.1
" 77 if(EXISTS "${file}
" AND 78 NOT IS_SYMLINK "${file}
") 83 if(CMAKE_INSTALL_DO_STRIP) 84 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 90 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 91 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
" AND 92 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
") 94 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
" 97 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOH5Rage-pv5.13.so
") 98 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
" AND 99 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
") 101 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
" 102 OLD_RPATH "\$ORIGIN:
" 103 NEW_RPATH "\$ORIGIN
") 104 if(CMAKE_INSTALL_DO_STRIP) 105 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOH5Rage-pv5.13.so
