1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLCompositeDataSetWriterHelper.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLDataWriterHelper.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPartitionedDataSetCollectionWriter.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPartitionedDataSetWriter.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLWriter2.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPDataObjectWriter.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPDataSetWriter.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPDataWriter.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPHierarchicalBoxDataWriter.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPHyperTreeGridWriter.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPImageDataWriter.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPMultiBlockDataWriter.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPPolyDataWriter.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPRectilinearGridWriter.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPStructuredDataWriter.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPStructuredGridWriter.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPTableWriter.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPUniformGridAMRWriter.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPUnstructuredDataWriter.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPUnstructuredGridWriter.h"
67  "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/ParallelXML/vtkIOParallelXMLModule.h"
68  )
69 endif()
70
71 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
72  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOParallelXML-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOParallelXML-hierarchy.txt")
73 endif()
74
75 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
76  foreach(file
77  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.6.0"
78  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.1"
79  )
80  if(EXISTS "${file}" AND
81  NOT IS_SYMLINK "${file}")
82  file(RPATH_CHECK
83  FILE "${file}"
84  RPATH "\$ORIGIN")
85  endif()
86  endforeach()
87  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
88  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelXML-pv6.0.so.6.0"
89  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelXML-pv6.0.so.1"
90  )
91  foreach(file
92  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.6.0"
93  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.1"
94  )
95  if(EXISTS "${file}" AND
96  NOT IS_SYMLINK "${file}")
97  file(RPATH_CHANGE
98  FILE "${file}"
99  OLD_RPATH "\$ORIGIN:"
100  NEW_RPATH "\$ORIGIN")
101  if(CMAKE_INSTALL_DO_STRIP)
102  execute_process(COMMAND "/usr/bin/strip" "${file}")
103  endif()
104  endif()
105  endforeach()
106 endif()
107
108 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
109  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so" AND
110  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so")
111  file(RPATH_CHECK
112  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so"
113  RPATH "\$ORIGIN")
114  endif()
115  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelXML-pv6.0.so")
116  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so" AND
117  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so")
118  file(RPATH_CHANGE
119  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so"
120  OLD_RPATH "\$ORIGIN:"
121  NEW_RPATH "\$ORIGIN")
122  if(CMAKE_INSTALL_DO_STRIP)
123  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so")
124  endif()
125  endif()
126 endif()
127
128 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
129  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/ParallelXML/vtkIOParallelXML.spdx")
130 endif()
131
