1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkAbstractImageInterpolator.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkExtractVOI.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkGenericImageInterpolator.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageAppendComponents.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageBlend.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageBSplineCoefficients.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageBSplineInternals.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageBSplineInterpolator.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageCacheFilter.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageCast.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageChangeInformation.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageClip.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageConstantPad.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageDataStreamer.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageDecomposeFilter.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageDifference.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageExtractComponents.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageFlip.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageInterpolator.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageIterateFilter.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageMagnify.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageMapToColors.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageMask.h"
70  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageMirrorPad.h"
71  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImagePadFilter.h"
72  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImagePermute.h"
73  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImagePointDataIterator.h"
74  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImagePointIterator.h"
75  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageProbeFilter.h"
76  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageResample.h"
77  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageResize.h"
78  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageReslice.h"
79  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageResliceToColors.h"
80  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageShiftScale.h"
81  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageShrink3D.h"
82  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageSincInterpolator.h"
83  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageStencilAlgorithm.h"
84  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageStencilData.h"
85  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageStencilIterator.h"
86  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageStencilSource.h"
87  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageSSIM.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageThreshold.h"
89  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageTranslateExtent.h"
90  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkImageWrapPad.h"
91  "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/vtkRTAnalyticSource.h"
92  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Imaging/Core/vtkImagingCoreModule.h"
93  )
94 endif()
95
96 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
97  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkImagingCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkImagingCore-hierarchy.txt")
98 endif()
99
100 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
101  foreach(file
102  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so.5.13"
103  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so.1"
104  )
105  if(EXISTS "${file}" AND
106  NOT IS_SYMLINK "${file}")
107  file(RPATH_CHECK
108  FILE "${file}"
109  RPATH "\$ORIGIN")
110  endif()
111  endforeach()
112  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
113  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkImagingCore-pv5.13.so.5.13"
114  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkImagingCore-pv5.13.so.1"
115  )
116  foreach(file
117  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so.5.13"
118  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so.1"
119  )
120  if(EXISTS "${file}" AND
121  NOT IS_SYMLINK "${file}")
122  file(RPATH_CHANGE
123  FILE "${file}"
124  OLD_RPATH "\$ORIGIN:"
125  NEW_RPATH "\$ORIGIN")
126  if(CMAKE_INSTALL_DO_STRIP)
127  execute_process(COMMAND "/usr/bin/strip" "${file}")
128  endif()
129  endif()
130  endforeach()
131 endif()
132
133 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
134  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so" AND
135  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so")
136  file(RPATH_CHECK
137  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so"
138  RPATH "\$ORIGIN")
139  endif()
140  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkImagingCore-pv5.13.so")
141  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so" AND
142  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so")
143  file(RPATH_CHANGE
144  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so"
145  OLD_RPATH "\$ORIGIN:"
146  NEW_RPATH "\$ORIGIN")
147  if(CMAKE_INSTALL_DO_STRIP)
148  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingCore-pv5.13.so")
149  endif()
150  endif()
151 endif()
152
153 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
154  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkImagingCore" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/Core/LICENSE")
155 endif()
156
