1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageAnisotropicDiffusion2D.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageAnisotropicDiffusion3D.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageCheckerboard.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageCityBlockDistance.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageConvolve.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageCorrelation.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageEuclideanDistance.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageEuclideanToPolar.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageGaussianSmooth.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageGradient.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageGradientMagnitude.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageHybridMedian2D.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageLaplacian.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageMedian3D.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageNormalize.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageRange3D.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageSeparableConvolution.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageSlab.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageSlabReslice.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageSobel2D.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageSobel3D.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageSpatialAlgorithm.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/Imaging/General/vtkImageVariance3D.h" 70 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Imaging/General/vtkImagingGeneralModule.h" 74 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 75 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkImagingGeneral-hierarchy.txt
vtk/hierarchy/ParaView/vtkImagingGeneral-hierarchy.txt
") 78 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 80 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so.5.13
" 81 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so.1
" 83 if(EXISTS "${file}
" AND 84 NOT IS_SYMLINK "${file}
") 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 91 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkImagingGeneral-pv5.13.so.5.13
" 92 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkImagingGeneral-pv5.13.so.1
" 95 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so.5.13
" 96 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so.1
" 98 if(EXISTS "${file}
" AND 99 NOT IS_SYMLINK "${file}
") 102 OLD_RPATH "\$ORIGIN:
" 103 NEW_RPATH "\$ORIGIN
") 104 if(CMAKE_INSTALL_DO_STRIP) 105 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 111 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 112 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
" AND 113 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
") 115 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
" 118 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkImagingGeneral-pv5.13.so
") 119 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
" AND 120 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
") 122 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
" 123 OLD_RPATH "\$ORIGIN:
" 124 NEW_RPATH "\$ORIGIN
") 125 if(CMAKE_INSTALL_DO_STRIP) 126 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.13.so
