1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkAddMembershipArray.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkAdjacencyMatrixToEdgeTable.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkArrayNorm.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkArrayToTable.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkCollapseGraph.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkCollapseVerticesByArray.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkContinuousScatterplot.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkDataObjectToTable.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkDotProductSimilarity.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkEdgeCenters.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkExpandSelectedGraph.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkExtractSelectedGraph.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkExtractSelectedTree.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkGenerateIndexArray.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkGraphHierarchicalBundleEdges.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkGroupLeafVertices.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkKCoreDecomposition.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMergeColumns.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMergeGraphs.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMergeTables.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMutableGraphHelper.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkNetworkHierarchy.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkPipelineGraphSource.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkPruneTreeFilter.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkRandomGraphSource.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkReduceTable.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkRemoveHiddenData.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkRemoveIsolatedVertices.h" 75 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkSparseArrayToTable.h" 76 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkStreamGraph.h" 77 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkStringToCategory.h" 78 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkStringToNumeric.h" 79 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToArray.h" 80 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToGraph.h" 81 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToSparseArray.h" 82 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToTreeFilter.h" 83 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkThresholdGraph.h" 84 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkThresholdTable.h" 85 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTransferAttributes.h" 86 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTransposeMatrix.h" 87 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTreeDifferenceFilter.h" 88 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTreeFieldAggregator.h" 89 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTreeLevelsFilter.h" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkVertexDegree.h" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkWordCloud.h" 92 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Infovis/Core/vtkInfovisCoreModule.h" 96 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 97 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkInfovisCore-hierarchy.txt
vtk/hierarchy/ParaView/vtkInfovisCore-hierarchy.txt
") 100 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 102 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so.5.13
" 103 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so.1
" 105 if(EXISTS "${file}
" AND 106 NOT IS_SYMLINK "${file}
") 109 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 112 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 113 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInfovisCore-pv5.13.so.5.13
" 114 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInfovisCore-pv5.13.so.1
" 117 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so.5.13
" 118 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so.1
" 120 if(EXISTS "${file}
" AND 121 NOT IS_SYMLINK "${file}
") 124 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 125 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 126 if(CMAKE_INSTALL_DO_STRIP) 127 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 133 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 134 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
" AND 135 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
") 137 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
" 138 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 140 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInfovisCore-pv5.13.so
") 141 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
" AND 142 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
") 144 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
" 145 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 146 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 147 if(CMAKE_INSTALL_DO_STRIP) 148 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.13.so
") 153 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 154 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkInfovisCore
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/LICENSE
