1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkCommunicator.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkDummyCommunicator.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkDummyController.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkFieldDataSerializer.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkMultiProcessController.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkMultiProcessStream.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkPDirectory.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkProcess.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkProcessGroup.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkPSystemTools.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkSocketCommunicator.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkSocketController.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkSubCommunicator.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkSubGroup.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkThreadedCallbackQueue.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkThreadedTaskQueue.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkMultiProcessStreamSerialization.h" 64 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Parallel/Core/vtkParallelCoreModule.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkThreadedCallbackQueue.txx" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/Parallel/Core/vtkThreadedTaskQueue.txx" 70 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 71 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkParallelCore-hierarchy.txt
vtk/hierarchy/ParaView/vtkParallelCore-hierarchy.txt
") 74 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 76 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so.5.13
" 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so.1
" 79 if(EXISTS "${file}
" AND 80 NOT IS_SYMLINK "${file}
") 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 87 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkParallelCore-pv5.13.so.5.13
" 88 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkParallelCore-pv5.13.so.1
" 91 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so.5.13
" 92 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so.1
" 94 if(EXISTS "${file}
" AND 95 NOT IS_SYMLINK "${file}
") 100 if(CMAKE_INSTALL_DO_STRIP) 101 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 107 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 108 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
" AND 109 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
") 111 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
" 114 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkParallelCore-pv5.13.so
") 115 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
" AND 116 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
") 118 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
" 119 OLD_RPATH "\$ORIGIN:
" 120 NEW_RPATH "\$ORIGIN
") 121 if(CMAKE_INSTALL_DO_STRIP) 122 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelCore-pv5.13.so
