1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAnnotatedCubeActor.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkArcPlotter.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxesActor.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxisActor.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxisActor2D.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxisFollower.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkBarChartActor.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCaptionActor2D.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkConvexHull2D.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCornerAnnotation.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCubeAxesActor.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCubeAxesActor2D.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkGraphAnnotationLayersFilter.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkLeaderActor2D.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkLegendBoxActor.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkLegendScaleActor.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkParallelCoordinatesActor.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkPieChartActor.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkPolarAxesActor.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkPolarAxesActor2D.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkProp3DAxisFollower.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkRadialGridActor2D.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkScalarBarActor.h"
70  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkSpiderPlotActor.h"
71  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkXYPlotActor.h"
72  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkScalarBarActorInternal.h"
73  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Annotation/vtkRenderingAnnotationModule.h"
74  )
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRenderingAnnotation-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingAnnotation-hierarchy.txt")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
82  foreach(file
83  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so.5.13"
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so.1"
85  )
86  if(EXISTS "${file}" AND
87  NOT IS_SYMLINK "${file}")
88  file(RPATH_CHECK
89  FILE "${file}"
90  RPATH "\$ORIGIN")
91  endif()
92  endforeach()
93  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
94  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingAnnotation-pv5.13.so.5.13"
95  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingAnnotation-pv5.13.so.1"
96  )
97  foreach(file
98  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so.5.13"
99  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so.1"
100  )
101  if(EXISTS "${file}" AND
102  NOT IS_SYMLINK "${file}")
103  file(RPATH_CHANGE
104  FILE "${file}"
105  OLD_RPATH "\$ORIGIN:"
106  NEW_RPATH "\$ORIGIN")
107  if(CMAKE_INSTALL_DO_STRIP)
108  execute_process(COMMAND "/usr/bin/strip" "${file}")
109  endif()
110  endif()
111  endforeach()
112 endif()
113
114 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
115  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so" AND
116  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so")
117  file(RPATH_CHECK
118  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so"
119  RPATH "\$ORIGIN")
120  endif()
121  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingAnnotation-pv5.13.so")
122  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so" AND
123  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so")
124  file(RPATH_CHANGE
125  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so"
126  OLD_RPATH "\$ORIGIN:"
127  NEW_RPATH "\$ORIGIN")
128  if(CMAKE_INSTALL_DO_STRIP)
129  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv5.13.so")
130  endif()
131  endif()
132 endif()
133
