1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/CellGrid 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/CellGrid/vtkDGRenderResponder.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/CellGrid/vtkOpenGLCellGridMapper.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/CellGrid/vtkRenderingCellGrid.h" 50 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/CellGrid/vtkRenderingCellGridModule.h" 54 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 55 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingCellGrid-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingCellGrid-hierarchy.txt
") 58 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 60 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so.5.13
" 61 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so.1
" 63 if(EXISTS "${file}
" AND 64 NOT IS_SYMLINK "${file}
") 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 71 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingCellGrid-pv5.13.so.5.13
" 72 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingCellGrid-pv5.13.so.1
" 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so.5.13
" 76 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so.1
" 78 if(EXISTS "${file}
" AND 79 NOT IS_SYMLINK "${file}
") 84 if(CMAKE_INSTALL_DO_STRIP) 85 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 91 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 92 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
" AND 93 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
") 95 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
" 98 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingCellGrid-pv5.13.so
") 99 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
" AND 100 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
") 102 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
" 103 OLD_RPATH "\$ORIGIN:
" 104 NEW_RPATH "\$ORIGIN
") 105 if(CMAKE_INSTALL_DO_STRIP) 106 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingCellGrid-pv5.13.so
