1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkDynamic2DLabelMapper.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkFreeTypeLabelRenderStrategy.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabeledDataMapper.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabeledTreeMapDataMapper.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelHierarchy.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelHierarchyAlgorithm.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelHierarchyCompositeIterator.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelHierarchyIterator.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelPlacementMapper.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelPlacer.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelRenderStrategy.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkLabelSizeCalculator.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/vtkPointSetToLabelHierarchy.h" 60 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Label/vtkRenderingLabelModule.h" 64 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 65 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingLabel-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingLabel-hierarchy.txt
") 68 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 70 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so.5.13
" 71 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so.1
" 73 if(EXISTS "${file}
" AND 74 NOT IS_SYMLINK "${file}
") 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 81 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingLabel-pv5.13.so.5.13
" 82 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingLabel-pv5.13.so.1
" 85 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so.5.13
" 86 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so.1
" 88 if(EXISTS "${file}
" AND 89 NOT IS_SYMLINK "${file}
") 94 if(CMAKE_INSTALL_DO_STRIP) 95 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 101 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 102 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
" AND 103 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
") 105 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
" 108 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingLabel-pv5.13.so
") 109 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
" AND 110 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
") 112 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
" 113 OLD_RPATH "\$ORIGIN:
" 114 NEW_RPATH "\$ORIGIN
") 115 if(CMAKE_INSTALL_DO_STRIP) 116 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingLabel-pv5.13.so
") 121 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 122 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRenderingLabel
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Label/LICENSE
