1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/OpenGL2/vtkOpenGLError.h" 48 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/OpenGL2/vtkRenderingOpenGLConfigure.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkArrayRenderer.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkCameraPass.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkClearRGBPass.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkClearZPass.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkCompositePolyDataMapper2.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDataTransferHelper.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDefaultPass.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDepthImageProcessingPass.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDepthOfFieldPass.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDepthPeelingPass.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDrawTexturedElements.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDualDepthPeelingPass.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkEDLShading.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkEquirectangularToCubeMapTexture.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkFramebufferPass.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGaussianBlurPass.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGenericOpenGLRenderWindow.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGLSLModCamera.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGLSLModCoincidentTopology.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGLSLModLight.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGLSLModPixelDebugger.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGLSLModifierBase.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkGLSLModifierFactory.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkHiddenLineRemovalPass.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkImageProcessingPass.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkLightingMapPass.h" 75 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkLightsPass.h" 76 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpaquePass.h" 77 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLActor.h" 78 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLArrayTextureBufferAdapter.h" 79 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLBatchedPolyDataMapper.h" 80 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLBillboardTextActor3D.h" 81 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLBufferObject.h" 82 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLCamera.h" 83 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLCellToVTKCellMap.h" 84 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLCompositePolyDataMapperDelegator.h" 85 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLES30PolyDataMapper2D.h" 86 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLFXAAFilter.h" 87 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLFXAAPass.h" 88 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLFluidMapper.h" 89 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLFramebufferObject.h" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLGL2PSHelper.h" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLGlyph3DHelper.h" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLGlyph3DMapper.h" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLHardwareSelector.h" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLHelper.h" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLHyperTreeGridMapper.h" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLImageAlgorithmHelper.h" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLImageMapper.h" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLImageSliceMapper.h" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLIndexBufferObject.h" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLInstanceCulling.h" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLLabeledContourMapper.h" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLLight.h" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLLowMemoryBatchedPolyDataMapper.h" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLLowMemoryPolyDataMapper.h" 105 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLPointGaussianMapper.h" 106 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLPolyDataMapper.h" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLPolyDataMapper2D.h" 108 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLProperty.h" 109 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLQuadHelper.h" 110 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLRenderPass.h" 111 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLRenderTimer.h" 112 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLRenderTimerLog.h" 113 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLRenderUtilities.h" 114 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.h" 115 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLRenderer.h" 116 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLShaderCache.h" 117 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLShaderProperty.h" 118 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLSkybox.h" 119 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLSphereMapper.h" 120 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLState.h" 121 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLStickMapper.h" 122 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLTextActor.h" 123 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLTextActor3D.h" 124 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLTextMapper.h" 125 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLTexture.h" 126 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLUniforms.h" 127 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLVertexArrayObject.h" 128 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLVertexBufferObject.h" 129 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLVertexBufferObjectCache.h" 130 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLVertexBufferObjectGroup.h" 131 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOrderIndependentTranslucentPass.h" 132 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOutlineGlowPass.h" 133 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOverlayPass.h" 134 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkPBRIrradianceTexture.h" 135 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkPBRLUTTexture.h" 136 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkPBRPrefilterTexture.h" 137 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkPanoramicProjectionPass.h" 138 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkPixelBufferObject.h" 139 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkPointFillPass.h" 140 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkRenderPassCollection.h" 141 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkRenderStepsPass.h" 142 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkRenderbuffer.h" 143 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkSSAAPass.h" 144 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkSSAOPass.h" 145 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkSequencePass.h" 146 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkShader.h" 147 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkShaderProgram.h" 148 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkShadowMapBakerPass.h" 149 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkShadowMapPass.h" 150 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkSimpleMotionBlurPass.h" 151 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkSobelGradientMagnitudePass.h" 152 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkTextureObject.h" 153 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkTextureUnitManager.h" 154 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkToneMappingPass.h" 155 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkTransformFeedback.h" 156 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkTranslucentPass.h" 157 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkValuePass.h" 158 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkVolumetricPass.h" 159 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkDummyGPUInfoList.h" 160 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkXOpenGLRenderWindow.h" 161 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkCompositeMapperHelper2.h" 162 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLPointGaussianMapperHelper.h" 163 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/OpenGL2/vtkOpenGLShaderDeclaration.h" 164 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/OpenGL2/vtkTextureObjectVS.h" 165 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/OpenGL2/vtkRenderingOpenGL2Module.h" 169 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 170 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingOpenGL2-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingOpenGL2-hierarchy.txt
") 173 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 175 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so.5.13
" 176 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so.1
" 178 if(EXISTS "${file}
" AND 179 NOT IS_SYMLINK "${file}
") 185 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 186 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingOpenGL2-pv5.13.so.5.13
" 187 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingOpenGL2-pv5.13.so.1
" 190 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so.5.13
" 191 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so.1
" 193 if(EXISTS "${file}
" AND 194 NOT IS_SYMLINK "${file}
") 197 OLD_RPATH "\$ORIGIN:
" 198 NEW_RPATH "\$ORIGIN
") 199 if(CMAKE_INSTALL_DO_STRIP) 200 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 206 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 207 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
" AND 208 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
") 210 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
" 213 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingOpenGL2-pv5.13.so
") 214 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
" AND 215 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
") 217 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
" 218 OLD_RPATH "\$ORIGIN:
" 219 NEW_RPATH "\$ORIGIN
") 220 if(CMAKE_INSTALL_DO_STRIP) 221 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingOpenGL2-pv5.13.so
") 226 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 227 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
" AND 228 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
") 230 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
" 231 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 233 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkProbeOpenGLVersion-pv5.13
") 234 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
" AND 235 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
") 237 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
" 238 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 239 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 240 if(CMAKE_INSTALL_DO_STRIP) 241 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkProbeOpenGLVersion-pv5.13
