1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkMPIPixelView.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkMPIPixelTT.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkParallelTimer.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkPLineIntegralConvolution2D.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkPPainterCommunicator.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkPPixelTransfer.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkPSurfaceLICComposite.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/ParallelLIC/vtkPSurfaceLICInterface.h" 55 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/ParallelLIC/vtkRenderingParallelLICModule.h" 59 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 60 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingParallelLIC-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingParallelLIC-hierarchy.txt
") 63 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 65 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so.5.13
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so.1
" 68 if(EXISTS "${file}
" AND 69 NOT IS_SYMLINK "${file}
") 72 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 75 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 76 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallelLIC-pv5.13.so.5.13
" 77 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallelLIC-pv5.13.so.1
" 80 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so.5.13
" 81 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so.1
" 83 if(EXISTS "${file}
" AND 84 NOT IS_SYMLINK "${file}
") 87 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 88 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 89 if(CMAKE_INSTALL_DO_STRIP) 90 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 96 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 97 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
" AND 98 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
") 100 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
" 101 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 103 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallelLIC-pv5.13.so
") 104 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
" AND 105 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
") 107 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
" 108 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 109 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 110 if(CMAKE_INSTALL_DO_STRIP) 111 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallelLIC-pv5.13.so
