1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Parallel/vtkCompositeZPassFS.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkClientServerCompositePass.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkClientServerSynchronizedRenderers.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositedSynchronizedRenderers.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositer.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositeRenderManager.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositeRGBAPass.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositeZPass.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompressCompositer.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkImageRenderManager.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkParallelRenderManager.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkPHardwareSelector.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkSynchronizedRenderers.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkSynchronizedRenderWindows.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkTreeCompositer.h" 62 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Parallel/vtkRenderingParallelModule.h" 66 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 67 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingParallel-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingParallel-hierarchy.txt
") 70 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so.5.13
" 73 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so.1
" 75 if(EXISTS "${file}
" AND 76 NOT IS_SYMLINK "${file}
") 79 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 83 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallel-pv5.13.so.5.13
" 84 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallel-pv5.13.so.1
" 87 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so.5.13
" 88 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so.1
" 90 if(EXISTS "${file}
" AND 91 NOT IS_SYMLINK "${file}
") 94 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 95 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 96 if(CMAKE_INSTALL_DO_STRIP) 97 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 103 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 104 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
" AND 105 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
") 107 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
" 108 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallel-pv5.13.so
") 111 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
" AND 112 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
") 114 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
" 115 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 116 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 117 if(CMAKE_INSTALL_DO_STRIP) 118 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv5.13.so
") 123 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 124 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRenderingParallel
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/LICENSE
