1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkActorNode.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkCameraNode.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkLightNode.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkMapperNode.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkPolyDataMapperNode.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkRendererNode.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkViewNode.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkViewNodeFactory.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkVolumeMapperNode.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkVolumeNode.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/SceneGraph/vtkWindowNode.h" 58 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/SceneGraph/vtkRenderingSceneGraphModule.h" 62 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 63 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingSceneGraph-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingSceneGraph-hierarchy.txt
") 66 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 68 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so.5.13
" 69 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so.1
" 71 if(EXISTS "${file}
" AND 72 NOT IS_SYMLINK "${file}
") 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 79 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingSceneGraph-pv5.13.so.5.13
" 80 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingSceneGraph-pv5.13.so.1
" 83 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so.5.13
" 84 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so.1
" 86 if(EXISTS "${file}
" AND 87 NOT IS_SYMLINK "${file}
") 92 if(CMAKE_INSTALL_DO_STRIP) 93 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 99 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 100 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
" AND 101 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
") 103 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
" 106 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingSceneGraph-pv5.13.so
") 107 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
" AND 108 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
") 110 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
" 111 OLD_RPATH "\$ORIGIN:
" 112 NEW_RPATH "\$ORIGIN
") 113 if(CMAKE_INSTALL_DO_STRIP) 114 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingSceneGraph-pv5.13.so
