1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkMultiBlockUnstructuredGridVolumeMapper.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkMultiBlockVolumeMapper.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLGPUVolumeRayCastMapper.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLProjectedTetrahedraMapper.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLRayCastImageDisplayHelper.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkSmartVolumeMapper.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkVolumeTexture.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeGradientOpacityTable.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeLookupTable.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeMaskGradientOpacityTransferFunction2D.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeMaskTransferFunction2D.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeOpacityTable.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeRGBTable.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeTransferFunction2D.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkVolumeInputHelper.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeLookupTables.h" 63 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/VolumeOpenGL2/vtkRenderingVolumeOpenGL2Module.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeLookupTables.txx" 68 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingVolumeOpenGL2-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingVolumeOpenGL2-hierarchy.txt
") 72 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so.5.13
" 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so.1
" 77 if(EXISTS "${file}
" AND 78 NOT IS_SYMLINK "${file}
") 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 85 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so.5.13
" 86 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so.1
" 89 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so.5.13
" 90 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so.1
" 92 if(EXISTS "${file}
" AND 93 NOT IS_SYMLINK "${file}
") 98 if(CMAKE_INSTALL_DO_STRIP) 99 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 105 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 106 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
" AND 107 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
") 109 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
" 112 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
") 113 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
" AND 114 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
") 116 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
" 117 OLD_RPATH "\$ORIGIN:
" 118 NEW_RPATH "\$ORIGIN
") 119 if(CMAKE_INSTALL_DO_STRIP) 120 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv5.13.so
