1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkBlockSortHelper.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkDirectionEncoder.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkEncodedGradientEstimator.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkEncodedGradientShader.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFiniteDifferenceGradientEstimator.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointRayCastImage.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeGOHelper.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeGOShadeHelper.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeHelper.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeShadeHelper.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastHelper.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastMapper.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastMIPHelper.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkGPUVolumeRayCastMapper.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkMultiVolume.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkOSPRayVolumeInterface.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkAnariVolumeInterface.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkProjectedTetrahedraMapper.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkRayCastImageDisplayHelper.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkRecursiveSphereDirectionEncoder.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkSphericalDirectionEncoder.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridBunykRayCastFunction.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridHomogeneousRayIntegrator.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridLinearRayIntegrator.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridPartialPreIntegration.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridPreIntegration.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridVolumeMapper.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayCastFunction.h" 75 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayCastIterator.h" 76 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayCastMapper.h" 77 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayIntegrator.h" 78 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkUnstructuredGridVolumeZSweepMapper.h" 79 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkVolumeMapper.h" 80 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkVolumeOutlineSource.h" 81 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkVolumePicker.h" 82 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkVolumeRayCastSpaceLeapingImageFilter.h" 83 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Volume/vtkRenderingVolumeModule.h" 87 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 88 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingVolume-hierarchy.txt
vtk/hierarchy/ParaView/vtkRenderingVolume-hierarchy.txt
") 91 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 93 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so.5.13
" 94 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so.1
" 96 if(EXISTS "${file}
" AND 97 NOT IS_SYMLINK "${file}
") 103 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 104 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolume-pv5.13.so.5.13
" 105 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolume-pv5.13.so.1
" 108 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so.5.13
" 109 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so.1
" 111 if(EXISTS "${file}
" AND 112 NOT IS_SYMLINK "${file}
") 115 OLD_RPATH "\$ORIGIN:
" 116 NEW_RPATH "\$ORIGIN
") 117 if(CMAKE_INSTALL_DO_STRIP) 118 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 124 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 125 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
" AND 126 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
") 128 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
" 131 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolume-pv5.13.so
") 132 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
" AND 133 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
") 135 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
" 136 OLD_RPATH "\$ORIGIN:
" 137 NEW_RPATH "\$ORIGIN
") 138 if(CMAKE_INSTALL_DO_STRIP) 139 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.13.so
") 144 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 145 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRenderingVolume
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/LICENSE
