1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkEmscriptenTestUtilities.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkPermuteOptions.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkTestDriver.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkTestErrorObserver.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkTestingColors.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkWindowsTestUtilities.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkTestUtilities.h"
54  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Testing/Core/vtkTestingCoreModule.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Testing/Core/vtkTestConditionals.txx"
56  )
57 endif()
58
59 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
60  foreach(file
61  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so.5.13"
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so.1"
63  )
64  if(EXISTS "${file}" AND
65  NOT IS_SYMLINK "${file}")
66  file(RPATH_CHECK
67  FILE "${file}"
68  RPATH "\$ORIGIN")
69  endif()
70  endforeach()
71  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
72  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkTestingCore-pv5.13.so.5.13"
73  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkTestingCore-pv5.13.so.1"
74  )
75  foreach(file
76  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so.5.13"
77  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so.1"
78  )
79  if(EXISTS "${file}" AND
80  NOT IS_SYMLINK "${file}")
81  file(RPATH_CHANGE
82  FILE "${file}"
83  OLD_RPATH "\$ORIGIN:"
84  NEW_RPATH "\$ORIGIN")
85  if(CMAKE_INSTALL_DO_STRIP)
86  execute_process(COMMAND "/usr/bin/strip" "${file}")
87  endif()
88  endif()
89  endforeach()
90 endif()
91
92 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
93  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so" AND
94  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so")
95  file(RPATH_CHECK
96  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so"
97  RPATH "\$ORIGIN")
98  endif()
99  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkTestingCore-pv5.13.so")
100  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so" AND
101  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so")
102  file(RPATH_CHANGE
103  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so"
104  OLD_RPATH "\$ORIGIN:"
105  NEW_RPATH "\$ORIGIN")
106  if(CMAKE_INSTALL_DO_STRIP)
107  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkTestingCore-pv5.13.so")
108  endif()
109  endif()
110 endif()
111
