1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/cgns/vtkcgns/src 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
47 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so.5.13" 48 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so.1" 50 if(EXISTS
"${file}" AND
51 NOT IS_SYMLINK
"${file}")
" TYPE SHARED_LIBRARY FILES 58 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkcgns-pv5.13.so.5.13
" 59 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkcgns-pv5.13.so.1
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so.5.13
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so.1
" 65 if(EXISTS "${file}
") 71 if(CMAKE_INSTALL_DO_STRIP) 72 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 78 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 79 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
" AND 80 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
") 82 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
" 85 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkcgns-pv5.13.so
") 86 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
" AND 87 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
") 89 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
" 92 if(CMAKE_INSTALL_DO_STRIP) 93 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkcgns-pv5.13.so
") 98 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 99 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkcgns/src
" TYPE FILE FILES 100 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/cgns/vtkcgns/src/vtk_cgns_mangle.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/cgns/vtkcgns/src/cgnslib.h
" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/cgns/vtkcgns/src/cgns_io.h
" 103 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/cgns/vtkcgns/src/cgnsconfig.h
" 104 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/cgns/vtkcgns/src/cgnstypes.h
