1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/diy2
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/diy2/vtkdiy2/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensex" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkdiy2" TYPE FILE FILES
52  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/diy2/vtkdiy2/LICENSE.txt"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/diy2/vtkdiy2/LEGAL.txt"
54  )
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/diy2/vtk_diy2.h")
59 endif()
60
