1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/diy2/vtkdiy2
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdiy2/" TYPE DIRECTORY FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/diy2/vtkdiy2/include")
47 endif()
48
