1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/doubleconversion/vtkdoubleconversion 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/double-conversion" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/bignum.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/
double-conversion/cached-powers.h
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/
diy-fp.h
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/
double-conversion.h
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/fast-dtoa.h
") 65 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/fixed-dtoa.h
") 69 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/ieee.h
") 73 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/strtod.h
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
double-conversion/utils.h
") 81 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkdoubleconversion/
double-conversion
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/
double-conversion/vtkdoubleconversion_export.h
") 85 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 87 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so.5.13
" 88 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so.1
" 90 if(EXISTS "${file}
" AND 91 NOT IS_SYMLINK "${file}
") 97 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 98 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkdoubleconversion-pv5.13.so.5.13
" 99 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkdoubleconversion-pv5.13.so.1
" 102 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so.5.13
" 103 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so.1
" 105 if(EXISTS "${file}
" AND 106 NOT IS_SYMLINK "${file}
") 110 NEW_RPATH "\$ORIGIN
") 111 if(CMAKE_INSTALL_DO_STRIP) 112 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 118 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 119 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
" AND 120 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
") 122 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
" 125 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkdoubleconversion-pv5.13.so
") 126 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
" AND 127 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
") 129 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
" 131 NEW_RPATH "\$ORIGIN
") 132 if(CMAKE_INSTALL_DO_STRIP) 133 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.13.so
