1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/exodusII/vtkexodusII 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkexodusII/include" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/exodusII/vtkexodusII/include/exodusII.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkexodusII/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/exodusII/vtkexodusII/include/exodusII_int.h
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkexodusII/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/exodusII/vtkexodusII/include/vtk_exodusII_mangle.h
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkexodusII/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/exodusII/vtkexodusII/include/exodusII_cfg.h
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkexodusII/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/exodusII/vtkexodusII/include/exodus_config.h
") 65 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so.5.13
" 68 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so.1
" 70 if(EXISTS "${file}
" AND 71 NOT IS_SYMLINK "${file}
") 74 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 77 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 78 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkexodusII-pv5.13.so.5.13
" 79 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkexodusII-pv5.13.so.1
" 82 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so.5.13
" 83 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so.1
" 85 if(EXISTS "${file}
" AND 86 NOT IS_SYMLINK "${file}
") 89 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 90 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 91 if(CMAKE_INSTALL_DO_STRIP) 92 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 98 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 99 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
" AND 100 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
") 102 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
" 103 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 105 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkexodusII-pv5.13.so
") 106 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
" AND 107 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
") 109 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
" 110 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 111 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 112 if(CMAKE_INSTALL_DO_STRIP) 113 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkexodusII-pv5.13.so
