1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkfast_float/vtkfast_float" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/ascii_number.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/bigint.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/decimal_to_binary.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/digit_comparison.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/fast_float.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/fast_table.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/float_common.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/parse_number.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/simple_decimal_conversion.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/fast_float/vtkfast_float/vtkfast_float/vtkfast_float_mangle.h"
