1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/hdf5/vtkhdf5/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensex" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkhdf5" TYPE FILE FILES
52  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/COPYING"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/COPYING_LBNL_HDF5"
54  )
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/hdf5/vtk_hdf5.h")
59 endif()
60
