1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkhdf5/src" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/hdf5.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5api_adpt.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5public.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/vtk_hdf5_mangle.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Apublic.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5ACpublic.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Cpublic.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Dpublic.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Epublic.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5ESdevelop.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5ESpublic.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Fpublic.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDcore.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDdevelop.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDdirect.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDfamily.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDhdfs.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDlog.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDmirror.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDmpi.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDmpio.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDmulti.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDpublic.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDros3.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDs3comms.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDsec2.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDsplitter.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDstdio.h" 75 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5FDwindows.h" 76 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Gpublic.h" 77 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Idevelop.h" 78 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Ipublic.h" 79 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Ldevelop.h" 80 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Lpublic.h" 81 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Mpublic.h" 82 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5MMpublic.h" 83 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Opublic.h" 84 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Ppublic.h" 85 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5PLextern.h" 86 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5PLpublic.h" 87 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Rpublic.h" 88 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Spublic.h" 89 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Tdevelop.h" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Tpublic.h" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5TSdevelop.h" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5VLconnector.h" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5VLconnector_passthru.h" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5VLnative.h" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5VLpassthru.h" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5VLpublic.h" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Zdevelop.h" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Zpublic.h" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Edefin.h" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Einit.h" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Epubgen.h" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5Eterm.h" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5version.h" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/src/H5overflow.h" 108 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 110 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so.5.13
" 111 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so.1
" 113 if(EXISTS "${file}
" AND 114 NOT IS_SYMLINK "${file}
") 120 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 121 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkhdf5-pv5.13.so.5.13
" 122 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkhdf5-pv5.13.so.1
" 125 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so.5.13
" 126 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so.1
" 128 if(EXISTS "${file}
" AND 129 NOT IS_SYMLINK "${file}
") 132 OLD_RPATH "\$ORIGIN:
" 133 NEW_RPATH "\$ORIGIN
") 134 if(CMAKE_INSTALL_DO_STRIP) 135 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 141 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 142 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
" AND 143 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
") 145 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
" 148 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkhdf5-pv5.13.so
") 149 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
" AND 150 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
") 152 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
" 153 OLD_RPATH "\$ORIGIN:
" 154 NEW_RPATH "\$ORIGIN
") 155 if(CMAKE_INSTALL_DO_STRIP) 156 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5-pv5.13.so
