1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkjpeg" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/jerror.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/jmorecfg.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/jpeglib.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/vtk_jpeg_mangle.h" 51 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/jpeg/vtkjpeg/jconfig.h" 55 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 57 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so.5.13
" 58 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so.1
" 60 if(EXISTS "${file}
" AND 61 NOT IS_SYMLINK "${file}
") 67 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 68 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkjpeg-pv5.13.so.5.13
" 69 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkjpeg-pv5.13.so.1
" 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so.5.13
" 73 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so.1
" 75 if(EXISTS "${file}
" AND 76 NOT IS_SYMLINK "${file}
") 81 if(CMAKE_INSTALL_DO_STRIP) 82 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 88 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 89 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
" AND 90 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
") 92 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
" 95 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkjpeg-pv5.13.so
") 96 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
" AND 97 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
") 99 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
" 101 NEW_RPATH "\$ORIGIN
") 102 if(CMAKE_INSTALL_DO_STRIP) 103 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.13.so
