1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xlibproj-datax" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/share/vtk-pv5.13/proj" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/proj.ini" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/world" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/other.extra" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/nad27" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/GL27" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/nad83" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/nad.lst" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/CH" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/ITRF2000" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/ITRF2008" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/ITRF2014" 58 "/builds/gitlab-kitware-sciviz-ci/build/lib64/../share/vtk-pv5.13/proj/proj.db" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/deformation_model.schema.json" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/projjson.schema.json" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/data/triangulation.schema.json"
