1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibproj/include/proj" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/util.hpp" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/metadata.hpp" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/common.hpp" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/crs.hpp" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/datum.hpp" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/coordinatesystem.hpp" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/coordinateoperation.hpp" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/io.hpp" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libproj/vtklibproj/include/proj/nn.hpp"
