1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/c14n.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/catalog.h")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/chvalid.h")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/debugXML.h")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/dict.h")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/encoding.h")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/entities.h")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/globals.h")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/hash.h")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/HTMLparser.h")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/HTMLtree.h")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/list.h")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/nanoftp.h")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/nanohttp.h")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/parser.h")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/parserInternals.h")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/pattern.h")
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/relaxng.h")
115 endif()
116
117 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/SAX.h")
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
122  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/SAX2.h")
123 endif()
124
125 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/schemasInternals.h")
127 endif()
128
129 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
130  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/schematron.h")
131 endif()
132
133 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
134  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/threads.h")
135 endif()
136
137 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
138  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/tree.h")
139 endif()
140
141 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
142  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/uri.h")
143 endif()
144
145 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
146  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/valid.h")
147 endif()
148
149 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
150  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/vtk_libxml2_mangle.h")
151 endif()
152
153 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
154  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xinclude.h")
155 endif()
156
157 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
158  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xlink.h")
159 endif()
160
161 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
162  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlIO.h")
163 endif()
164
165 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
166  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlautomata.h")
167 endif()
168
169 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
170  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlerror.h")
171 endif()
172
173 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
174  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlexports.h")
175 endif()
176
177 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
178  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlmemory.h")
179 endif()
180
181 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
182  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlmodule.h")
183 endif()
184
185 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
186  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlreader.h")
187 endif()
188
189 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
190  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlregexp.h")
191 endif()
192
193 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
194  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlsave.h")
195 endif()
196
197 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
198  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlschemas.h")
199 endif()
200
201 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
202  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlschemastypes.h")
203 endif()
204
205 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
206  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlstring.h")
207 endif()
208
209 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
210  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlunicode.h")
211 endif()
212
213 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
214  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlwriter.h")
215 endif()
216
217 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
218  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xpath.h")
219 endif()
220
221 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
222  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xpathInternals.h")
223 endif()
224
225 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
226  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xpointer.h")
227 endif()
228
229 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
230  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklibxml2/include/libxml" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlversion.h")
231 endif()
232
233 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
234  foreach(file
235  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so.5.13"
236  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so.1"
237  )
238  if(EXISTS "${file}" AND
239  NOT IS_SYMLINK "${file}")
240  file(RPATH_CHECK
241  FILE "${file}"
242  RPATH "\$ORIGIN")
243  endif()
244  endforeach()
245  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
246  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklibxml2-pv5.13.so.5.13"
247  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklibxml2-pv5.13.so.1"
248  )
249  foreach(file
250  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so.5.13"
251  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so.1"
252  )
253  if(EXISTS "${file}" AND
254  NOT IS_SYMLINK "${file}")
255  file(RPATH_CHANGE
256  FILE "${file}"
257  OLD_RPATH "\$ORIGIN:"
258  NEW_RPATH "\$ORIGIN")
259  if(CMAKE_INSTALL_DO_STRIP)
260  execute_process(COMMAND "/usr/bin/strip" "${file}")
261  endif()
262  endif()
263  endforeach()
264 endif()
265
266 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
267  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so" AND
268  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so")
269  file(RPATH_CHECK
270  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so"
271  RPATH "\$ORIGIN")
272  endif()
273  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklibxml2-pv5.13.so")
274  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so" AND
275  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so")
276  file(RPATH_CHANGE
277  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so"
278  OLD_RPATH "\$ORIGIN:"
279  NEW_RPATH "\$ORIGIN")
280  if(CMAKE_INSTALL_DO_STRIP)
281  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.13.so")
282  endif()
283  endif()
284 endif()
285
