1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/base.h")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/bcj.h")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/block.h")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/check.h")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/container.h")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/delta.h")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/filter.h")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/hardware.h")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/index.h")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/index_hash.h")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/lzma12.h")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/stream_flags.h")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/version.h")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/vli.h")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtklzma/src/liblzma/api" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/vtk_lzma_mangle.h")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
110  foreach(file
111  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so.5.13"
112  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so.1"
113  )
114  if(EXISTS "${file}" AND
115  NOT IS_SYMLINK "${file}")
116  file(RPATH_CHECK
117  FILE "${file}"
118  RPATH "\$ORIGIN")
119  endif()
120  endforeach()
121  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
122  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklzma-pv5.13.so.5.13"
123  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklzma-pv5.13.so.1"
124  )
125  foreach(file
126  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so.5.13"
127  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so.1"
128  )
129  if(EXISTS "${file}" AND
130  NOT IS_SYMLINK "${file}")
131  file(RPATH_CHANGE
132  FILE "${file}"
133  OLD_RPATH ":::::::"
134  NEW_RPATH "\$ORIGIN")
135  if(CMAKE_INSTALL_DO_STRIP)
136  execute_process(COMMAND "/usr/bin/strip" "${file}")
137  endif()
138  endif()
139  endforeach()
140 endif()
141
142 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
143  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so" AND
144  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so")
145  file(RPATH_CHECK
146  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so"
147  RPATH "\$ORIGIN")
148  endif()
149  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklzma-pv5.13.so")
150  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so" AND
151  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so")
152  file(RPATH_CHANGE
153  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so"
154  OLD_RPATH ":::::::"
155  NEW_RPATH "\$ORIGIN")
156  if(CMAKE_INSTALL_DO_STRIP)
157  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.13.so")
158  endif()
159  endif()
160 endif()
161
version
index
