1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/mpi4py/vtkmpi4py/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensex" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkmpi4py" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py/vtkmpi4py/LICENSE.rst")
52 endif()
53
