1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py/vtkmpi4py/src 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/mpi4py/__init__.py" 48 "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/mpi4py/__init__.pxd" 49 "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/mpi4py/MPI.pxd" 50 "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/mpi4py/mpi.cfg" 54 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xUnspecifiedx
" OR NOT CMAKE_INSTALL_COMPONENT) 55 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
" AND 56 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
") 58 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
" 59 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 61 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py
" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/mpi4py/MPI.so
") 62 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
" AND 63 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
") 65 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
" 66 OLD_RPATH "/usr/lib64/openmpi/lib:/builds/gitlab-kitware-sciviz-ci/build/lib64:
" 67 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 68 if(CMAKE_INSTALL_DO_STRIP) 69 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/mpi4py/MPI.so
") 74 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 75 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmpi4py/mpi4py/
" TYPE DIRECTORY FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py/vtkmpi4py/src/mpi4py/include/mpi4py/
