1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/netcdf/vtknetcdf 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtknetcdf/include" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/netcdf/vtknetcdf/include/netcdf.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtknetcdf/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/netcdf/vtknetcdf/include/netcdf_filter_build.h
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtknetcdf/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/netcdf/vtknetcdf/include/vtk_netcdf_mangle.h
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtknetcdf/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/netcdf/vtknetcdf/include/netcdf_dispatch.h
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtknetcdf/include
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/netcdf/vtknetcdf/include/netcdf_meta.h
") 65 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtknetcdf
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/netcdf/vtknetcdf/vtk_netcdf_config.h
") 69 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 71 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so.5.13
" 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so.1
" 74 if(EXISTS "${file}
" AND 75 NOT IS_SYMLINK "${file}
") 78 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 81 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 82 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtknetcdf-pv5.13.so.5.13
" 83 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtknetcdf-pv5.13.so.1
" 86 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so.5.13
" 87 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so.1
" 89 if(EXISTS "${file}
" AND 90 NOT IS_SYMLINK "${file}
") 93 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 94 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 95 if(CMAKE_INSTALL_DO_STRIP) 96 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 102 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 103 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
" AND 104 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
") 106 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
" 107 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 109 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtknetcdf-pv5.13.so
") 110 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
" AND 111 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
") 113 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
" 114 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 115 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 116 if(CMAKE_INSTALL_DO_STRIP) 117 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtknetcdf-pv5.13.so
