1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/theora/vtktheora
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtktheora/include/theora" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/theora/vtktheora/include/theora/codec.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtktheora/include/theora" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/theora/vtktheora/include/theora/theora.h")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtktheora/include/theora" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/theora/vtktheora/include/theora/theoradec.h")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtktheora/include/theora" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/theora/vtktheora/include/theora/theoraenc.h")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtktheora/include/theora" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/theora/vtktheora/include/theora/vtk_theora_mangle.h")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtktheora/include/theora" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/theora/vtktheora/include/theora/vtktheora_export.h")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
70  foreach(file
71  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so.5.13"
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so.1"
73  )
74  if(EXISTS "${file}" AND
75  NOT IS_SYMLINK "${file}")
76  file(RPATH_CHECK
77  FILE "${file}"
78  RPATH "\$ORIGIN")
79  endif()
80  endforeach()
81  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
82  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktheora-pv5.13.so.5.13"
83  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktheora-pv5.13.so.1"
84  )
85  foreach(file
86  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so.5.13"
87  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so.1"
88  )
89  if(EXISTS "${file}" AND
90  NOT IS_SYMLINK "${file}")
91  file(RPATH_CHANGE
92  FILE "${file}"
93  OLD_RPATH "\$ORIGIN:"
94  NEW_RPATH "\$ORIGIN")
96  execute_process(COMMAND "/usr/bin/strip" "${file}")
97  endif()
98  endif()
99  endforeach()
100 endif()
101
102 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
103  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so" AND
104  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so")
105  file(RPATH_CHECK
106  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so"
107  RPATH "\$ORIGIN")
108  endif()
109  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktheora-pv5.13.so")
110  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so" AND
111  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so")
112  file(RPATH_CHANGE
113  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so"
114  OLD_RPATH "\$ORIGIN:"
115  NEW_RPATH "\$ORIGIN")
116  if(CMAKE_INSTALL_DO_STRIP)
117  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktheora-pv5.13.so")
118  endif()
119  endif()
120 endif()
121
