1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Compiler.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Hash.h
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Singletons.h
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Token.h
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Type.h
") 65 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/TypeContainer.h
") 69 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Manager.h
") 73 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token/json
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/json/jsonToken.h
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token/json
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/json/jsonManager.h
") 81 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/Options.h
") 85 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/CxxABIConfigure.h
") 89 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/Exports.h
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 95 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.5.13
" 96 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.1
" 98 if(EXISTS "${file}
" AND 99 NOT IS_SYMLINK "${file}
") 105 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 106 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktoken-pv5.13.so.5.13
" 107 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktoken-pv5.13.so.1
" 110 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.5.13
" 111 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.1
" 113 if(EXISTS "${file}
" AND 114 NOT IS_SYMLINK "${file}
") 118 NEW_RPATH "\$ORIGIN
") 119 if(CMAKE_INSTALL_DO_STRIP) 120 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 126 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 127 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
" AND 128 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
") 130 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
" 133 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktoken-pv5.13.so
") 134 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
" AND 135 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
") 137 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
" 139 NEW_RPATH "\$ORIGIN
") 140 if(CMAKE_INSTALL_DO_STRIP) 141 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so
") 146 if(NOT CMAKE_INSTALL_LOCAL_ONLY) 147 # Include the install script for the subdirectory. 148 include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/testing/cmake_install.cmake
