1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/utf8
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/utf8/vtkutf8/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensex" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkutf8" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/utf8/vtkutf8/LICENSE")
52 endif()
53
54 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/utf8/vtk_utf8.h")
56 endif()
57
