1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/cmake_install.cmake")
50 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensex
" OR NOT CMAKE_INSTALL_COMPONENT) 51 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/LICENSE.txt
