1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkmstd/cmake_install.cmake")
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51 # Include the install script for the subdirectory. 52 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/optionparser/cmake_install.cmake")
55 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
56 # Include the install script for the subdirectory. 57 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/diy/cmake_install.cmake")
60 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
61 # Include the install script for the subdirectory. 62 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/lcl/cmake_install.cmake")
65 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
66 # Include the install script for the subdirectory. 67 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/loguru/cmake_install.cmake")
70 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
71 # Include the install script for the subdirectory. 72 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/cmake_install.cmake")
75 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
76 # Include the install script for the subdirectory. 77 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/cuda/cmake_install.cmake")
80 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
81 # Include the install script for the subdirectory. 82 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/kokkos/cmake_install.cmake")
85 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
86 # Include the install script for the subdirectory. 87 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/openmp/cmake_install.cmake")
90 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
91 # Include the install script for the subdirectory. 92 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/serial/cmake_install.cmake")
95 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
96 # Include the install script for the subdirectory. 97 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/cmake_install.cmake")
100 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
101 # Include the install script for the subdirectory. 102 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/testlib/cmake_install.cmake")
105 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
106 # Include the install script for the subdirectory. 107 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/cmake_install.cmake")
110 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
111 # Include the install script for the subdirectory. 112 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/cuda/cmake_install.cmake")
115 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
116 # Include the install script for the subdirectory. 117 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/kokkos/cmake_install.cmake")
120 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
121 # Include the install script for the subdirectory. 122 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/openmp/cmake_install.cmake")
125 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
126 # Include the install script for the subdirectory. 127 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/serial/cmake_install.cmake")
130 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
131 # Include the install script for the subdirectory. 132 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/cmake_install.cmake")
135 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
136 # Include the install script for the subdirectory. 137 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/worklet/cmake_install.cmake")
140 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
141 # Include the install script for the subdirectory. 142 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/cmake_install.cmake")
145 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
146 # Include the install script for the subdirectory. 147 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/clean_grid/cmake_install.cmake")
150 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
151 # Include the install script for the subdirectory. 152 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/connected_components/cmake_install.cmake")
155 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
156 # Include the install script for the subdirectory. 157 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/vector_analysis/cmake_install.cmake")
160 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
161 # Include the install script for the subdirectory. 162 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/mesh_info/cmake_install.cmake")
165 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
166 # Include the install script for the subdirectory. 167 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/multi_block/cmake_install.cmake")
170 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
171 # Include the install script for the subdirectory. 172 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/contour/cmake_install.cmake")
175 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
176 # Include the install script for the subdirectory. 177 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/geometry_refinement/cmake_install.cmake")
180 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
181 # Include the install script for the subdirectory. 182 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/density_estimate/cmake_install.cmake")
185 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
186 # Include the install script for the subdirectory. 187 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/entity_extraction/cmake_install.cmake")
190 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
191 # Include the install script for the subdirectory. 192 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/field_conversion/cmake_install.cmake")
195 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
196 # Include the install script for the subdirectory. 197 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/field_transform/cmake_install.cmake")
200 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
201 # Include the install script for the subdirectory. 202 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/flow/cmake_install.cmake")
205 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
206 # Include the install script for the subdirectory. 207 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/image_processing/cmake_install.cmake")
210 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
211 # Include the install script for the subdirectory. 212 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/resampling/cmake_install.cmake")
215 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
216 # Include the install script for the subdirectory. 217 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/scalar_topology/cmake_install.cmake")
220 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
221 # Include the install script for the subdirectory. 222 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/uncertainty/cmake_install.cmake")
225 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
226 # Include the install script for the subdirectory. 227 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/zfp/cmake_install.cmake")
230 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
231 # Include the install script for the subdirectory. 232 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/interop/cmake_install.cmake")
235 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
236 # Include the install script for the subdirectory. 237 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/lodepng/cmake_install.cmake")
240 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
241 # Include the install script for the subdirectory. 242 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/cmake_install.cmake")
245 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
246 # Include the install script for the subdirectory. 247 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/random/cmake_install.cmake")
250 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
251 # Include the install script for the subdirectory. 252 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/source/cmake_install.cmake")
255 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
256 # Include the install script for the subdirectory. 257 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cmake_install.cmake")
260 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
261 # Include the install script for the subdirectory. 262 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/docs/users-guide/cmake_install.cmake")
265 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xUnspecifiedx
" OR NOT CMAKE_INSTALL_COMPONENT) 266 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/config/vtkm_config.mk
") 269 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 270 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm
vtkm/vtkvtkm/
vtk-m/config/
vtkm.pc
") 273 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 274 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm
" TYPE FILE RENAME "VTKmREADME.md
" FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/README.md
") 277 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 278 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm
" TYPE FILE RENAME "VTKmLICENSE.txt
vtkm/vtkvtkm/
vtk-m/LICENSE.txt
") 281 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 282 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm" TYPE FILE FILES 283 "/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-5.13/
vtk/
vtkm/VTKmConfig.cmake
" 284 "/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-5.13/
vtk/
vtkm/VTKmConfigVersion.cmake
" 288 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 289 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm/cmake
" TYPE FILE FILES 290 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmCMakeBackports.cmake
" 291 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/FindTBB.cmake
" 292 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/patches/FindMPI.cmake
" 296 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 297 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm/cmake/3.15
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/patches/3.15/FindMPI.cmake
") 300 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 301 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm/cmake
" TYPE FILE FILES 302 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmCPUVectorization.cmake
" 303 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmDetectCUDAVersion.cu
" 304 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmDeviceAdapters.cmake
" 305 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmDIYUtils.cmake
" 306 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmExportHeaderTemplate.h.in
" 307 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmRenderingContexts.cmake
" 308 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMake/VTKmWrappers.cmake
" 312 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 313 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm/VTKmTargets.cmake
") 314 file(DIFFERENT EXPORT_FILE_CHANGED FILES 315 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
" 316 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/CMakeFiles/Export/lib64/cmake/paraview-5.13/
vtk/
") 317 if(EXPORT_FILE_CHANGED) 318 file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm/VTKmTargets-*.cmake
") 320 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
321 file(REMOVE ${OLD_CONFIG_FILES})
325 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk/
") 326 if("${CMAKE_INSTALL_CONFIG_NAME}
" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$
") 327 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/
vtk/
vtkm/vtkvtkm/
vtk/
vtkm/VTKmTargets-debug.cmake
") 331 if(NOT CMAKE_INSTALL_LOCAL_ONLY) 332 # Include the install script for the subdirectory. 333 include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/examples/cmake_install.cmake
