1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/io" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/BOVDataSetReader.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/DecodePNG.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/EncodePNG.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ErrorIO.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/FileUtils.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderBase.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderPNG.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderPNM.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageUtils.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterBase.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterPNG.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterPNM.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/PixelTypes.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetReader.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetReaderBase.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetWriter.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKPolyDataReader.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKRectilinearGridReader.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKStructuredGridReader.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKStructuredPointsReader.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKUnstructuredGridReader.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKVisItFileReader.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/PixelTypes.hxx"
70  )
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/io" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/include/vtkm/io/vtkm_io_export.h")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/io" TYPE FILE FILES
79  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/BOVDataSetReader.h"
80  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/DecodePNG.h"
81  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/EncodePNG.h"
82  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ErrorIO.h"
83  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/FileUtils.h"
84  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderBase.h"
85  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderPNG.h"
86  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderPNM.h"
87  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageUtils.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterBase.h"
89  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterPNG.h"
90  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterPNM.h"
91  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/PixelTypes.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetReader.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetReaderBase.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetWriter.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKPolyDataReader.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKRectilinearGridReader.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKStructuredGridReader.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKStructuredPointsReader.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKUnstructuredGridReader.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKVisItFileReader.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/PixelTypes.hxx"
102  )
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
106  foreach(file
107  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2.0"
108  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2"
109  )
110  if(EXISTS "${file}" AND
111  NOT IS_SYMLINK "${file}")
112  file(RPATH_CHECK
113  FILE "${file}"
114  RPATH "$ORIGIN")
115  endif()
116  endforeach()
117  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
118  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_io-pv5.13.so.2.2.0"
119  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_io-pv5.13.so.2.2"
120  )
121  foreach(file
122  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2.0"
123  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2"
124  )
125  if(EXISTS "${file}" AND
126  NOT IS_SYMLINK "${file}")
127  file(RPATH_CHANGE
128  FILE "${file}"
129  OLD_RPATH "\$ORIGIN:"
130  NEW_RPATH "$ORIGIN")
131  if(CMAKE_INSTALL_DO_STRIP)
132  execute_process(COMMAND "/usr/bin/strip" "${file}")
133  endif()
134  endif()
135  endforeach()
136 endif()
137
138 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
139  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so" AND
140  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so")
141  file(RPATH_CHECK
142  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so"
143  RPATH "$ORIGIN")
144  endif()
145  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_io-pv5.13.so")
146  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so" AND
147  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so")
148  file(RPATH_CHANGE
149  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so"
150  OLD_RPATH "\$ORIGIN:"
151  NEW_RPATH "$ORIGIN")
152  if(CMAKE_INSTALL_DO_STRIP)
153  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so")
154  endif()
155  endif()
156 endif()
157
158 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
159  # Include the install script for the subdirectory.
160  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/internal/cmake_install.cmake")
161 endif()
162
