1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/source 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/source" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/include/vtkm/source/vtkm_source_export.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xUnspecifiedx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/
source" TYPE FILE FILES 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/
source/Amr.h
" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/
source/Oscillator.h
" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/
source/Source.h
" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/
source/Tangle.h
" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/
source/Wavelet.h
" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/
source/PerlinNoise.h
" 60 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so.2.2.0
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so.2.2
" 65 if(EXISTS "${file}
") 72 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 73 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_source-pv5.13.so.2.2.0
" 74 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_source-pv5.13.so.2.2
" 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so.2.2.0
" 78 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so.2.2
" 80 if(EXISTS "${file}
" AND 81 NOT IS_SYMLINK "${file}
") 86 if(CMAKE_INSTALL_DO_STRIP) 87 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 94 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
" AND 95 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
") 97 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
" 100 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_source-pv5.13.so
") 101 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
" AND 102 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
") 104 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
" 105 OLD_RPATH "\$ORIGIN:
" 107 if(CMAKE_INSTALL_DO_STRIP) 108 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_source-pv5.13.so
