1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMAppHelper.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMCallback.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMConfig.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMFile.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMParser.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMParserMap.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/DICOMTypes.h" 54 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/DICOMParser/DICOMCMakeConfig.h" 55 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/DICOMParser/vtkDICOMParserModule.h" 59 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 61 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so.5.13
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so.1
" 64 if(EXISTS "${file}
" AND 65 NOT IS_SYMLINK "${file}
") 71 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 72 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDICOMParser-pv5.13.so.5.13
" 73 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDICOMParser-pv5.13.so.1
" 76 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so.5.13
" 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so.1
" 79 if(EXISTS "${file}
" AND 80 NOT IS_SYMLINK "${file}
") 85 if(CMAKE_INSTALL_DO_STRIP) 86 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 92 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 93 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
" AND 94 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
") 96 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
" 99 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDICOMParser-pv5.13.so
") 100 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
" AND 101 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
") 103 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
" 104 OLD_RPATH "\$ORIGIN:
" 105 NEW_RPATH "\$ORIGIN
") 106 if(CMAKE_INSTALL_DO_STRIP) 107 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDICOMParser-pv5.13.so
") 112 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 113 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkDICOMParser
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/DICOMParser/Copyright.txt
