1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWIML/vtkkwiml
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkkwiml" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWIML/vtkkwiml/include/kwiml/abi.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWIML/vtkkwiml/include/kwiml/int.h"
49  )
50 endif()
51
