1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWSys/vtksys
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Directory.hxx")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/DynamicLoader.hxx")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Encoding.hxx")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Glob.hxx")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/RegularExpression.hxx")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/SystemTools.hxx")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/CommandLineArguments.hxx")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/FStream.hxx")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/SystemInformation.hxx")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Status.hxx")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Configure.h")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/SharedForward.h")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Process.h")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Base64.h")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Encoding.h")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/MD5.h")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/System.h")
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/Configure.hxx")
115 endif()
116
117 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtksys" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWSys/vtksys/String.hxx")
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
122  foreach(file
123  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so.5.13"
124  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so.1"
125  )
126  if(EXISTS "${file}" AND
127  NOT IS_SYMLINK "${file}")
128  file(RPATH_CHECK
129  FILE "${file}"
130  RPATH "\$ORIGIN")
131  endif()
132  endforeach()
133  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
134  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtksys-pv5.13.so.5.13"
135  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtksys-pv5.13.so.1"
136  )
137  foreach(file
138  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so.5.13"
139  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so.1"
140  )
141  if(EXISTS "${file}" AND
142  NOT IS_SYMLINK "${file}")
143  file(RPATH_CHANGE
144  FILE "${file}"
145  OLD_RPATH ":::::::"
146  NEW_RPATH "\$ORIGIN")
147  if(CMAKE_INSTALL_DO_STRIP)
148  execute_process(COMMAND "/usr/bin/strip" "${file}")
149  endif()
150  endif()
151  endforeach()
152 endif()
153
154 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
155  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so" AND
156  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so")
157  file(RPATH_CHECK
158  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so"
159  RPATH "\$ORIGIN")
160  endif()
161  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtksys-pv5.13.so")
162  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so" AND
163  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so")
164  file(RPATH_CHANGE
165  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so"
166  OLD_RPATH ":::::::"
167  NEW_RPATH "\$ORIGIN")
168  if(CMAKE_INSTALL_DO_STRIP)
169  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtksys-pv5.13.so")
170  endif()
171  endif()
172 endif()
173
