1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/Python 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/Python/vtkPython.h" 48 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/Python/vtkPythonConfigure.h"
