1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter/vtkPVWebGLExporter.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter/vtkWebGLDataSet.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter/vtkWebGLExporter.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter/vtkWebGLObject.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter/vtkWebGLPolyData.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Web/WebGLExporter/vtkWebGLWidget.h"
53  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Web/WebGLExporter/vtkWebGLExporterModule.h"
54  )
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkWebGLExporter-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkWebGLExporter-hierarchy.txt")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
62  foreach(file
63  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so.5.13"
64  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so.1"
65  )
66  if(EXISTS "${file}" AND
67  NOT IS_SYMLINK "${file}")
68  file(RPATH_CHECK
69  FILE "${file}"
70  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
71  endif()
72  endforeach()
73  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
74  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWebGLExporter-pv5.13.so.5.13"
75  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWebGLExporter-pv5.13.so.1"
76  )
77  foreach(file
78  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so.5.13"
79  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so.1"
80  )
81  if(EXISTS "${file}" AND
82  NOT IS_SYMLINK "${file}")
83  file(RPATH_CHANGE
84  FILE "${file}"
85  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
86  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
87  if(CMAKE_INSTALL_DO_STRIP)
88  execute_process(COMMAND "/usr/bin/strip" "${file}")
89  endif()
90  endif()
91  endforeach()
92 endif()
93
94 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
95  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so" AND
96  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so")
97  file(RPATH_CHECK
98  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so"
99  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
100  endif()
101  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWebGLExporter-pv5.13.so")
102  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so" AND
103  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so")
104  file(RPATH_CHANGE
105  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so"
106  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
107  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
108  if(CMAKE_INSTALL_DO_STRIP)
109  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWebGLExporter-pv5.13.so")
110  endif()
111  endif()
112 endif()
113
