1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Python
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/generate_pyi.py")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtk.py")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/__init__.py")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/all.py")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/gtk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/gtk/GtkGLExtVTKRenderWindow.py")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/gtk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/gtk/GtkGLExtVTKRenderWindowInteractor.py")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/gtk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/gtk/GtkVTKRenderWindow.py")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/gtk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/gtk/GtkVTKRenderWindowInteractor.py")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/gtk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/gtk/__init__.py")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/numpy_interface" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/numpy_interface/__init__.py")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/numpy_interface" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/numpy_interface/algorithms.py")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/numpy_interface" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/numpy_interface/dataset_adapter.py")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/numpy_interface" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/numpy_interface/internal_algorithms.py")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/qt" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/qt/QVTKRenderWindowInteractor.py")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/qt" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/qt/__init__.py")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/test" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/test/BlackBox.py")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/test" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/test/ErrorObserver.py")
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/test" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/test/Testing.py")
115 endif()
116
117 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/test" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/test/rtImageTest.py")
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
122  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/test" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/test/__init__.py")
123 endif()
124
125 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/tk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/tk/__init__.py")
127 endif()
128
129 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
130  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/tk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/tk/vtkLoadPythonTkWidgets.py")
131 endif()
132
133 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
134  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/tk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/tk/vtkTkImageViewerWidget.py")
135 endif()
136
137 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
138  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/tk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/tk/vtkTkPhotoImage.py")
139 endif()
140
141 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
142  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/tk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/tk/vtkTkRenderWidget.py")
143 endif()
144
145 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
146  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/tk" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/tk/vtkTkRenderWindowInteractor.py")
147 endif()
148
149 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
150  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/__init__.py")
151 endif()
152
153 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
154  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/colors.py")
155 endif()
156
157 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
158  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/data_model.py")
159 endif()
160
161 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
162  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/execution_model.py")
163 endif()
164
165 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
166  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/keys.py")
167 endif()
168
169 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
170  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/misc.py")
171 endif()
172
173 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
174  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/numpy_support.py")
175 endif()
176
177 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
178  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/pickle_support.py")
179 endif()
180
181 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
182  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/vtkAlgorithm.py")
183 endif()
184
185 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
186  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/vtkConstants.py")
187 endif()
188
189 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
190  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/vtkImageExportToArray.py")
191 endif()
192
193 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
194  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/vtkImageImportFromArray.py")
195 endif()
196
197 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
198  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/vtkMethodParser.py")
199 endif()
200
201 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
202  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/util/vtkVariant.py")
203 endif()
204
205 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
206  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/wx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/wx/__init__.py")
207 endif()
208
209 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
210  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/wx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/wx/wxVTKRenderWindow.py")
211 endif()
212
213 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
214  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/vtkmodules/wx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/vtkmodules/wx/wxVTKRenderWindowInteractor.py")
215 endif()
216
